River_Lizard
- Jan 17, 2012
- 378
What's the weight of a 2.5 liter and anything bad about this year of 4 cylinder mercruisers?
I dread to even post this response but Bond-o asked me to post it here instead of the PM I sent him........ouch!!
Here goes..........
I want to switch the Crestliner from an OB to a I/O that's in my Sig. I know I know.... maximum capacity levels of drive for boat. Hence the request for weights. I know I'd have to raise the transom level and was figuring to raise it 4 additional inches and including the cap area at the rear of the boat for the length of the motor housing.
Factory OB rating is:
85 HP
6 persons or 150 lbs each.
1535 max load.
I figure if I change the person level to only 4 persons or 600 lbs max. I would have 935 lbs to work with for fuel and drive. That would NOT be adding the increase in the transom level or the additional height of the rear section of the boat. I know they (CG) figure a line of plane on the side of the boat and this is my major concern on calculating max load for floatation. I've looked at a few drawings but I'm not getting how they determine the line of plane and then use that with the width, beam, length, etc...of the boat to get that figure for the plate.
I have a chance to purchase a complete boat with a GM 2.5L w/alpha1 drive and trailer for under $700.00 . The trailer looks like it would work for the base of a custom trailer I want to build for the Crestliner so that helps with the $$. The owner states that the engine runs great and the outdrive and is willing to put it on muffs for me.
Not sure there's anything I could do to a 2.5 to reduce the overall weight of it.....there's not much to them already.
I don't want the boat sitting like it's climbing a hill when it's just sitting in the water so my game plan was to move the 12 gallon fuel tank to the bow of the boat to help level off the balance and also to allow to add some additional foam to the rear of the boat.
Any suggestions????
OK Bond-o.....are you happy? :lol: As I turn three shades of red.....and shaking my head on why I even considered posting this here.
River_Lizard said:Bond-o
I reason I'm asking is because I want to put a I/O in the Crestliner that's in my Sig. I know I'll have to extend the transom up which will give me a little more maximum pound capacity for the boat hull but my target weight is around 800 lbs. It sounds like the 4 cylinder is the only way I could go with an I/O.
The Crestliner needs a new transom and stringers so this would be the time to make the change if it's at all possible. I figured if I relocated the fuel tank to the bow of the boat it would help even the weight load overall. Figure a 12-14 gallon tank would be enough for a 4 cylinder. This would also allow me to put more foam in the rear of the boat also.
Extending the transom and making a raised deck above the engine would increase the measurements for determining drive weight for the boat...is this not correct? If it's determined that I need additional floatation, couldn't I add two extensions on either side of the outdrive as step-ups to would also increase the floatation of the boat?
I really want to change the drive system to an I/O vs OB for a couple of reasons, 1. fuel usesage 2. noise reduction This boat is more of a pleasure/sightseeing/water skiing for the wife and daughter. I'd really like to be able to talk while we're motoring places without having to yell over an OB motor.
Any suggestions?
Thanks,
Jeff
Here goes..........
85 HP
1535 max load.
Any suggestions????
What's wrong with the motor on it, other than the Noise,..??
Other than it's an electric shift and it has water flow issues internally ....nothing. With the servo issues these motors have, I'd rather get something a little more reliable but also quieter too. With this boat I'd like to get away from the 2 cycle noise. The new 4 strokes that I've seen you don't even know they're running at idle and at 60 throttle they're super quiet.
