Weight of a 1978 55 hp Johnson
DawsonRH
I am considering getting a 1978 Johnson 55 Horse power, remote control. Don't know exact model, I need to know the weight. I looked around for a while and have been unable to find anything. Thanks alot!
Rudi2
Re: Weight of a 1978 55 hp Johnson
Don't have exact figures, but I believe about 210 lbs.
DawsonRH
WOW! You are sure of this ballpark? I was really hoping it was something less... thats almost twice my '93 30hp.
bktheking
Copied and pasted from another site.
Weight of Older Outboard Motors
The following are typical OMC motors and weights found on classic Whalers. Weights taken from the 1992 Evinrude catalog.
2 cylinder, 521 cc platform, 20/25/30/35 HP
15 inch shaft, rope start -- 115 lbs
15 inch shaft, elec. start -- 118 lbs
20 inch shaft, rope start -- 117 lbs
20 inch shaft, elec. start -- 120 lbs
This bullet proof motor platform had a run from 1976 to ~2005. Often found on classic 13, 15 & sometimes as twins on 17 Montauks
2 cylinder 737 cc platform, 40/48/50/55/60 HP
20 inch shaft, elec. start, man. tilt -- 190 lbs
20 inch shaft, elec. start, trim/tilt -- 195 lbs
These motors populated the transoms of 13s, 15s and some 17 Montauks.
3 cylinder 849/920 cc platform, 50/60/70 HP
20 inch shaft, elec. start, man. tilt -- 237 lbs
20 inch shaft, elec. start, trim/tilt -- 250 lbs
(This motor used to displace ~849 cc and was about 10 lbs lighter)
Often found on 15s, 17 Montauks, sometimes as twins on 18/20 Outrages and 20 Revenges.
V4 1632 cc platform, 85/88/90/100/115 HP
20 inch shaft, elec. start, man. tilt -- 288 lbs
20 inch shaft, elec. start, trim/tilt -- 301 lbs
25 inch shaft, elec. start, trim/tilt -- 311 lbs
Often hanging on the transoms of 17 Montauks(85-100 HP), 17/18 Outrage (115 HP), 22 Outrage/Revenge as twins (90-115 HP).
V4 2000 cc (loop charge) platform, 120/130/140 HP
20 inch shaft, elect. start, trim/tilt -- 365 lbs
25 inch shaft, elect. start, trim/tilt -- 370 lbs
Seen on 17/18 Outrages & as twins on 22 Outrage/Revenge incl. WD, 22 Outrage/Revenge Whaler Drive ("WD"), 25 Outrage/Revenge incl. WD.
V6 2448 cc (cross flow, 90 degree) platform, 150 HP
20 inch shaft, elec. start, trim/tilt -- 397 lbs
25 inch shaft, elec. start, trim/tilt -- 402 lbs
V6 2589 cc (loop charge, 60 degree) platform, 150/175 HP
20 inch shaft, elec. start, trim/tilt -- 370 lbs
25 inch shaft, elec. start, trim/tilt -- 375 lbs
Often seen hanging on the transom of 18 & 20 Outrages, sometime on 22 Outrage/Revenge (as single) & on 22 Outrage/Revenge WD and 25 Outrage/Revenge as twins.
V6 3000 cc (loop charge) platform, 200/225 HP
25 inch shaft, elec. start, trim/tilt -- 455 lbs.
25 inch shaft, elec. start, trim/tilt, power steering -- 480 lbs.
(This platform started out with lesser displacement (~2700 cc) and slightly lighter weight)
Commonly seen on 22/25 Outrage/Revenges as singles and sometimes as twins on 25 Outrage/Revenge/Temptation WDs.
V8 4000 cc (loop charge) platform, 250/275/300 HP
25 inch shaft, elect. start, trim/tilt -- 555 lbs
25 inch shaft, elect. start, trim/tilt, power steering -- 580 lbs.
