k_krobbins
Thread starter- Joined
- Jun 12, 2010
- 15
The water stream does not come out with much pressure on muffs or in the water. After a few minutes overheat alarm comes on.
I am use to water squirting out of these hoses when running
2004 Merc 3cyl. 2 stroke ser#OT899429
1-I have put new water impeller.
2-New thermostat.
3-While t-stat out i backflushed the peestream hose until water flowed out from t-stat housing for a minute.
4-Installed new t-stat and no water would flow out of hose.
5-Removed t-stat and water flows but still what i would call a weak stream, and alarm sounds after running about 5 minutes.
Does this engine have another water pump?
Could sender unit be bad and coming on too soon at lower temp?
2-New thermostat.
