Weak spark
fredipuppy
New long block after spun bearing(1+ yr ago), thought I'd hook it up and it would light off 1st crank.
Now I'm getting frustrated.
New coil, new breaker plate, points and condenser.
Wiring- neg side, 1 wire coil to points and 2 wire shift interrupter and overstroke sw.
+ pos side, 1 wire 2.5 ohm resistor (run) and 1 wire 12ish vdc from solenoid start position.
No matter what I disconnect. weak yellow spark.
Even with just points to neg coil and temp wire direct pos coil to batt....weak spark..NO START...just little puffs
sounds like antique hit or miss engine.
:confused:
Levinz11
Re: Weak spark
Grounds good and clean/tight? Coil and plug wires checking out OK? Do you have 12V to the coil while cranking?
bruceb58
Re: Weak spark
What is your dwell set at? Measured with a dwell meter?
What is voltage to the coil with the points closed?
And just a thought, I have had bad condensers out of the box before.
Re: Weak spark
Ayuh,.... Welcome Aboard,.... Change the Points, 'n Condenser,...
