weak spark on no 2 plug
Bandit0014
Hi peoples took my motor for a tune & was told it has weak spark on no 2 cylinder no 1 &3 have good spark & they said the compression check came back with 150 in each cylinder i noticed the coils had cracks & replaced all three with no improvement could it be the stator still starts & runs its a 1973 65hp evinrude triumph model no 65373R cheers any help would be good & a place to buy a new stator for it in australia i can get a second hand stator for $140 is that cheap
Joe Reeves
Re: weak spark on no 2 plug
If the stator was bad, you would not have good spark on any cylinder. Check the spark yourself, the spark (with the spark plugs removed) should jump a 7/16" gap with a strong blue lightning like flame... a real SNAP!
Unless that stator has cracks that is allowing a sticky looking substance drip down on the timer base and powerhead, I would assume it is good.
Check all connections pertaining to the ignition... loose, tight but dirty, poor grounds, etc.
Faztbullet
It could be a problem in pack. This pack has a single capacitor to to fire the coils so if you had a damaged SCR or solder connection, it could have weak output to that coil and others OK. You can test the output to coil with a meter and DVA adapter.
Bandit0014
Thanks guys i went over the motor today & found alot of resin from the stator is sitting on the top of the block melted so i,d say it could be it
Joe Reeves
Make sure that it is leaking from your present stator.... and NOT from a possible previous stator.
If from the present stator, then replace it regardless. I've never seen a failing stator affect just one clyinder though.
boobie
I vote for a bad pack or sensor but it should be checked out with a peak reading or dva meter.
