Re: Weak pee stream hot also bad -weak pump?
Play it safe and have a look at the water pump impellor.
Unless you actualy do it yourself and see waht your putting in,then never take the word of a previous sellor.
it sounds like the impellor is bad to me, take note that just by looking you still might not notice a impellor thats bad.
check the impellor hub is not the problem !!!!!!!
recently i took down a johnson 140hp water pump and the impellor looked like brand new, it turned out the
hub was just spinning and the blades not hardly moving.
the previous owner even tried to bodge up the water pump body with silicone thinking it could be the housing.
obviously he didnt notice the blades of impellor were good but the hub itself was just spinning.
best thing is to take it out and realy inspect it to be sure its a good one.
this impellor when inside the pump housing looked realy perfect and like new .
pic below showing a bad impellor hub !!Note the hub has become seperate from the rubber !!!!!!
phill
