Does that amount of water seem excessive to you and others? And that's a remove the powerhead fix?If you can't see a leak inside the cowling, there is a seal on top of the water tube where the water enters the powerhead.....if it was leaking bad enough could be the cause of the overheat problem...not enough water pressure.
Agreed, airshot.....Never saw water comming from that area before !! Especially that much...
