Water Temp Light 2004 175 Johnson
kingers26
The water temp light comes on about 3 minutes after initial start up. If I try to throttle up the engine the S.L.O.W. kicks in. The engine never feels hot, I can hold my hand against it no problem. I am getting good flow from the indicator so I replaced the t-stats and the light still came on. When I got home I checked the old t-stats and they were both working properly. I pulled the t-stat covers while flushing to see if I was getting water to the heads and I was. In addition, my warning horn is not sounding.
Any Ideas would be much appreciated!!!
tashasdaddy
Re: Water Temp Light 2004 175 Johnson
bad sensor, and bad horn possibly.
JB
What the heck prompted you to post this in the Trailers and Towing forum, Kingers??
Moving to JohnnyRudes
kingers26
Thanks tashasdaddy... I figured that was porobably the case, but wanted to make sure before buying the sensors. Is there a way to check if I'm getting water flow on the otherside of the t-stats.
