Water Temp Guage Inop
LegacyT
Is there a way to test whether its the gauge or sender on the manifold? What typically goes first on the AQ231A?
Don S
Re: Water Temp Guage Inop
With the ignition switch in the run position, take the gauge sender wire off the sender and tap it on a good clean ground. If the gauge pegs hot, the gauge is working.
