Re: Water Temp. Gauge
You should have a t-stat in there, maybe the previous owner had a problem with it being stuck open/close? and just removed it instead of replacing it. I still have a hard time believing that even without one the temp never went above 100 deg. If the t-stat doesn't fix your problem then get a meter like Merc200 says and meter between engine block ground and the sender, if it's open (infinite resistance) bad sender, at room temp 75 deg you should see approx 400-700 ohms, as it warms up the resistance drops and the guage increases, you saw this when you shorted the wire out, so if you ran the engine for a while the resistance should drop to around 100 ohms.
