Re: water temp gauge
Although I cannot give you the answer I believe you are hoping for as far as how to go about installing a best method to monitor engine temp. There are ways to go about installing a temp gauge. However, one method requires the removal of the overheat thermoswitch in the cylinder head to make way for a probe of a battery powered remote digital thermometer. Performance of the probe pretty much requires that the probe be placed in the same location as the overheat thermoswitch and that it be epoxied into place. Although, cheap and realatively easy to install, getting rid of your engines overheat alarm I believe may not be a wise idea. Grumpy II mentioned the water plug located ontop the head directly above the thermostat housing. Some people use this location to install either a tell tail or as I decided, to install a dashboard mounted pressure gauge to monitor water pump operation. Although, neither method monitors temp. Such methods do allow for keeping an eye on whether or not water is flowing through the motor which does offer some comfort in that aspect. It also allows one a manner in which to tell when your engines water pump maybe worn or faulty by noting a decrease in pressure over the life of the engine.
