water spray coming over transom
dstjay
we have a legend v-149 widebody boat with low very steep angled transom, with a 2 stroke 30hp mercury long shaft motor on it we find that there ia a lot of water spray off the motor that is splashing over into the boat. does anyone have any suggestions on how to fix this?
smokeonthewater
20" transom? 25" motor?
If so you need a jack plate.
Look for a "mini jacker" 'bout $100 or so
Ayuh,.... Welcome Aboard,.... Put the Right motor on it,..... I'm guessin' yer's is 5 or 10" too Deep,.....
A jack-plate raises the CG of the hull,.....
dstjay
is that to raise motor higher out of the water? cause it is too long and its to low in the water? thks much
southkogs
Essentially "yes," but more to raise the screw/propeller up. The anti-ventilation plate on the outboard should be just below the keel/hull of the boat ... maybe an inch or so ... to operate properly.
phillipgo
Maybe add a jack plate and install it as high as possible. Sounds like a 20" on a 15" transom.
Watermann
Post up some pics of your set up and include a shot of the motor all the way tucked down. Do you have a transducer on the transom?
