water restriction
Gil Manor
Hi,
I think I have water restriction in my Mercury 50HP EFI cooling system.
What is the best way to clear the restriction if it is not moud or sand but worse like salt deposits or even aluminium oxids.
Gil
pistol37
Re: water restriction
Depending on the year, you could have a bigger problem. If you are comfortable with working on your motor, you can remove the lower unit and attempt to blow water directly through the water tube. You could just have a simple blockage or ....here's the bad news-the grommet between the watertube and adapter plates of these motors causes an obstruction. E-mail me if you have any more questions @ stromis37@hotmail.com.
