Water Pump
fdlguy32
Just successfully replaced the water pump kit on my 89 mercruiser alpha one. Not to bad of a job as long as you take your time. Only problem is I originally took apart my housing for the thermostat and tore up part of the gasket. Now I have a slight leak.
Anyone suggest making my own gasket or getting some liquid gasket to solve the problem?
searay3
Re: Water Pump
Buy or make one, don't use silicone unless the manual calls for it. There it does not.
dubs283
Re: Water Pump
make your own gasket
go to parts store
ask for gasket material
they will give you an 8x10 sheet of it
cr2k
Re: Water Pump
If your t-stat housing has a temp sender in the top part you should buy the correct gasket that has the grommets that make the electrical ground for the sender.
Re: Water Pump
Buy a new gasket. They are not that expensive and cr2k is right on the money about the grounding grommets.
fdlguy32
Re: Water Pump
Thanks guys, I was wondering what those things were on the gasket. I thought since 95 percent of the gasket was still intact I could maybe get away with just filling in the part that isn't with some liquid gasket. Grounding part of it is still in tip-top shape. I'm not looking for the easy way out or cheap out considering the gasket is only 3 bones.
jimbo_jwc
Ship Happens
Re: Water Pump
Bolts holding thermostat housing aren't good ground ? Are they to be thread sealed when installed and don't make good enough connection ? Brass NTP temp sending unit
installed bare for good grnd. ? I need to do mine too for I opened up to see what it looked like and size and ending up peening one from what i had laying around and it still
works without leaking so far but will be ordering one soon 23yr old boat .
cr2k
Re: Water Pump
Yes the bolts should be gooped with gasket sealing compound or they may never come apart again.
The grommets weren't just put there for S&G they serve a purpose as all things marine that don't make sence to car mechanics.
No it's not "just" a chevy V-8 it is a Marine engine, big diff.
Do you really want to trust a patched gasket 30 miles out to sea?
Re: Water Pump
Ayuh,... Gaskets in general, especially paper gaskets, are NOT reusable parts,....
Go buy a New 1...
fdlguy32
Re: Water Pump
Ok, I got the new gasket on with no more leaking but now it seems like the engine isn't warming up to operating temp. Did I possibly ruin the thermostat when it overheated before I changed out the water pump. Could it be that those grounding tabs on the gasket aren't getting a good ground? One thing after another.
Brentathon
Re: Water Pump
Check continuity between the body of the temp sender and the engine, and that should tell you if your T-stat housing is grounded.
I have a separate ground wire that's clamped to the body of my temp sender, with a small hose clamp, so I don't have to rely on the little grounding grommets in the gasket.
fdlguy32
Re: Water Pump
Checked for continuity and it was good. I guess I should wait until I get it out on the water and have the RPM's up for a bit. Although I ran it plenty of times last year on the muffs at Idle and it seemed to open up at like 175 and know it stays at like 140.
jimbo_jwc
Ship Happens
Re: Water Pump
Not just car mechanic but would neverseize serve purpose as bolt heads contact thermostat casting and threads contact block casting ? Smeared enough antiseize around old ford truck starter nose to loose ground
connection . Sr. Master Tech
