Water Pump
lmdickens
i need directions to change water pump on a 1982 115 johnson thanks
tashasdaddy
Re: Water Pump
if you are extremely mechanically inclined.
you have to release the shift rod under the bottom carb. then remove the 7 bolts on the lower unit.
lmdickens
Re: Water Pump
thanks i thought there was an easier way .guess not will have to get some help
