Water Pump tell-tale - 73 65hp Evinrude
Scooter
I'm new to my 73 65hp Evinrude. I do not see any water spewing out any small holes indicating that the water pump is working. Does this model have any tell-tale holes?<br /><br />Also, under the thermostat housing I have the thermostat and 2 springs pressing on 2 plastic valves. What are these 2 plastic valves for. The tension on the springs seem so great that I couldn't image water pressure opening the valves. what are they for?<br /><br />Thanks
Capt Ron
Re: Water Pump tell-tale - 73 65hp Evinrude
Pressure relief valve. Engine should operate between 125º and 163º as measured on the block.<br />Good Luck<br />Capt Ron
Capt Ron
Scooter
Oh, is it like a backup device to the thermostat? If the therm failes, the pressure builds up and opens the valves! Or do the relief valves operate independent of the thernostat?
