water pump replacement
tblshur
im helping a friend put a water pump kit in a 96 Johnson ,j88tsledr vid says to put adhesive on both sides of the first gasket if recommended can we use black , or ultra blue permatex or something else .any other pointers on this job would be greatly appreciated thanks.:)
Re: water pump replacement
A thin smear of ultra blue works well.----------Note---- a thin smear is all that is needed. Often we see way too much sealant used.
boobie
I myself would use Permatex # 3.
tblshur
thanks guys for the quick response.understand thin smear and permatex#3 thanks again:joyous:
oldboat1
so racerone, who's "we?" If you are in the business, it would be useful to know your specialties for future reference. Mostly J and E?
tblshur
oldboat1 I just got the new oem parts ,will try to do the job in 1wk or so.the instructions that came with kit says to apply adhesive 847 at several places in the pump, not sure what 847 is or if something else would work I understand you don't want a gob of something that could dislodge and stop something up I ordered factory service manual for this motor.will wait for it before doing repairs. I really thank all you guys for your help.:joyous:
oldboat1
sounds like the gasket sealant (or rather, a sealant) as discussed earlier. You would probably get it right yourself, and all kinds of advice on this disc. board, but good idea to wait for the service manual -- particularly when working on a friend's motor. Be nice if you could keep the service manual, or at least have access to it once the job is done. Good luck.
