Water pump replacement help. Johnson 9.9 1981
TrainerRed
So my motor was running, but after replacing the water pump the motor no longer wants to turn on. Strange I know. I'm a nooby at this stuff but previously my motor did not want to run until after I replaced the fuel pump. I replaced the fuel pump about 2 weeks ago, it ran but I noticed there was no water coming out to keep the motor cool so I ordered a water pump kit and it finally came in and replaced it. Now it doesn't turn on... I just want to fish on a boat and not shore!
Tl;dr Replaced water pump and now motor doesn't turn on.
Any ideas and suggestions? Please and thanks!
Newyota
Don,t focus on the water pump replacement.It won't cause engine not to start.Have you checked the spark?Make a air gap spark checker or buy one.I did and it was worth it to check spark.Changed plugs?Gone over carb?Compression?These are things most people will tell you check first even if it ran before.Just got done with an issue on a 9.9 and it ended up being a blown head gasket and after going over carb and checking spark and new plugs a compression check told the story.
TrainerRed
I got the motor about a month ago and I switched out the plugs, rebuilt carb with kit, not a handy man so I don't have tools for compression check but my motor turned on just last week with one try after replacing the fuel pump so I'm puzzled. There are no leaks on my fuel lines but they are loose when plugged in. They can twist a bit (but no liquid or gas comes out that I can see). I need to find the size of the fuel line tube and will be replacing them.
Crosbyman
dont go replacing things for nothing ... proceed systematically...
sudden failure must be broken down ....... air fuel compression ???
assuming ...for now compression did not fail & fuel is fresh no crud ​ ?
​ start with checking fuel flow .... pump screen ok ? disconnect carb inlet and pump the line... is fuel flowing towards the carb ok ? vent open tank pick-up clean
​ if you squirt some fuel in the carb does it fire up a bit or remains totally dead
​verify sparking on the grounded plugs ...do they both fire decently ..
Newyota
When we buy these old motors We turn into handy men that's for sure.May want to invest in a compression gauge,I ended up doing that for same reason you may need one.Good luck..
rolmops
Is it an electric start or a pull start? When you say "does not turn on" do you mean that the engine does not turn over or does it turn over ,but it does not start?
If it does not turn over ,you should check the wiring to the battery and double check the ground. Often when lower units are taken off, the wires get jerked around a bit.Also make sure that the fuel hose with the ball is not put on backward. That will prevent the engine from starting.
TrainerRed
Yeah I won't replace things for no reason I'm trying to save money or I'd just have someone service it. My fuel pump was cracked so I replaced it. People said a carb rebuild would be wise. And after I got it running there was no water coming out and I understand that is how these motors are kept cool. I looked up some stuff and it lead me to the water pump and the impeller was completely wore out. It was shattered to pieces basically.
Not sure about compression because I do not have a gauge and the fuel is fresh. I will be replacing a certain fuel line that runs from fuel pump to the carb because there is a very small leak. Bubbles are coming out and not straight fluid. My spark plugs are fine. I have yet to try spraying fluid inside the carb but will give it a try when I'm off work. Thanks!
TrainerRed
It is a pull start. It turns over but will not start. This is my first motor so I'm not familiar where the wires to the battery and ground are. But I'll do some searching around. Thanks!
TrainerRed
Replaced from fuel line and it started with ease. Thanks everyone for concern and advice.
Bonaventure
You say you are not a handyman? With all the work you have done on his motor some of us may disagree. You asked questions but found out yourself what the problem was
