1998 J150. New motor to me, going through things and replacing. 1st project will be water pump. What wont I get with the WP kit that I will need to order seperatly? Best I can tell from my manual is I should order: Upper/lower exhaust housing adapter seals, drive shaft grommet,water tube seal ? anything experiance has taught you guys/gals to order "just in case" ?
Thanks, Tom
Thanks, Tom
