Water Pump Problems
brotherandrew
I have 3 different HP Mercury motors and they all run great but none of them spit water when they run. one of them did at first and than stopped is that the water pump or something else? They have been out of the water for acouple of years now or so, i think. Thanks
DHPMARINE
Re: Water Pump Problems
Generally speaking the pumps should be done every other year or so.When sitting they seem to dry out and stop working.For any overheat or not pumping problem,the best place to begin is the waterpump.<br /><br />DHP
Motor Boater Bill
Bugs like to nest in the "pee hole" or telltale where the water comes out, and the hose above the pee hole. Make sure it is clear. A flexible wire or piece of string-trimmer string works well for this. I have had them completely stopped up by mud-dobbers, and after clearing them they worked fine.
