water pump problems 93 evin 60
SJNJTN08
I've changed the impeller and can't get any water out of the top of motor.Any solutions.
reeldutch
Re: water pump problems 93 evin 60
you mean there is no water comming out of the tell tale ?
or did you take the tstats of and there is still no water comming out?
may be a blockage in the watertube?
Benny1963
check your water tube pull and clen out passages and replace thermo with full kit make sure tube alignment is correct check that keeper for impellar didnt shear
good luck bennyb
SJNJTN08
I changed my impeller because the water flow droped on me on the lake two days ago. No the problem is worse. How long does it take for the thermostat to open. I get a little stream but not much. I'm scared to run it too long on the hose.
