water pump parts problem
chobeeboy
1 have a 1976 135 hp evinrude and im changing the water pump, i can find all the internal parts but i cant find new housing, mine has two holes for water to travel, if anyone could help would appreciate thanks
bktheking
Re: water pump parts problem
Does it need a new housing?? Is the housing damaged? Of the one's I have done I typically change just the impeller.
chobeeboy
yes it cracked where you bolt down the cap that holds the rubber seals in
bktheking
shop2.evinrude.com lists them as still being available, see below.
0318933 IMPELLER HOUSING ASSY.. Models with "D" Suffix Contents of Water Pump Repair Kit
0385801 IMPELLER HOUSING ASSY.. Contents of Water Pump Repair Kit Models with "G" Suffix
chobeeboy
i tried looking there but i just couldnt find maybe im not looking right:confused:
bktheking
Find your year, find your motor model, click on gearcase, look to the left, it shows the pump housing.
F_R
The original aluminum pump housings are no longer made (thankfully). You need to buy a 439140 water pump kit that includes everything to update it to the plastic pump with stainless steel liners. You get it at an Evinrude dealer.
chobeeboy
does any body know how to figure out what G or D suffix i need for my water pump
wilde1j
It's part of the model no. Check the last character on the data plate (port side of mounting bracket or stamped on freeze plug (top aft part of motor). The BRP PL shows the same PN for both variations, so the pump PN F_R posted above probably OK for both.
