5150abf
Thread starter- Joined
- Aug 12, 2007
- 5,808
Re: Water pump-need help
I have confirmed the water pump is pumping,took the lower off stuck it in a trash can,filled it with water, put a peice of gas hose on the drive shaft, put a drill bit in the other end of the hose and hooked to a drill,shot water 3' into the air.
Pulled the tstat and releif valve put water on the pick up tube and it put water out the tell tale first then the tstat hole.
SO I think the problem was the tstat, it seems to flow water everywhere it is suppose to.
Like I said, tonight is the first time the tstat has been out of the engine since it was built, 27 years is a pretty good service life.
I will get it back together tomorro and hopefully be done.
