Water pump locked up?
Duckski
I put the ear muffs to my 3.0 mercruiser after a long winter, only to hear the belt squealing when it first started up. I also noticed that the pulley for the waterpump was not turning, so I guess the waterpump is locked up? What does the panel think?
Thanks,
Zackman
Re: Water pump locked up?
I know I squeal when I first get up after a long sleep....​
You may want to loosen the belt and see if you can turn the cooling water pump by hand. Should turn easy with no looseness or noise.​
Bt Doctur
Was it left dry for the winter or winterized with A/F?
Duckski
All was winterized, got it ready for the water, wanted to fire it up before I got to the ramp just in case, glad I did. Had a minute to check it out, deffinitely locked up, going to tear it down tomorrow.
Don S
Put a new pump in it. IF it's locked up now, it will be leaking very soon or lock up again, maybe somewhere out on the water.
Duckski
Do it right the first time Don, you won't have to do it again! Or get stranded out on the water without a paddle, but thanks
