Water Pump Impeller
billthom
I Have A 1997 Johnson 35 Hp That I'm Going To Change The Water Pump Impeller Any Problem In Just Dropping Lower Unit & Changing It?
Fl_Richard
Re: Water Pump Impeller
Should be a snap proided you have removed the shift lever linkage.
kenmyfam
Should not be a problem. I do however suggest that you have a OEM manual available. Strange things are found when going into the "unknown"
