water pump help!!!!!
3000gtman
1980 evinrude 75 sport...sat for 5yrs. She fired up and decent pisser stream while I've been messing with carb rebuild and other issues. She ran ok. Good pisser stream until I went to the lake. Put her in water and no pisser....immediately turned engine off. Good psi. 165psi in all 3 cylinders. I ordered new water pump kit. Installed new kit with new key and gaskets. Lubed impeller housing up. Started engine with water muffs on. Pisser was very strong!! Next day took her to lake. Same thing no pisser!!! Hooked up water muffs and no pisser. Removed lower unit again and found the supply tube had some gashes on it. I inspected the tube running down the motor. No marks. I replaced my water supply tube with the original one to my old water pump.
I was pretty sure I installed the lower unit correctly last time.maybe the copper Tube wasn't in all the way..Im almost positive it was tho..
Any thoughts? I reinstalled lower unit today and made dang sure the tube is all the way in. I havnt tested water flow yet since it started to storm
oldboat1
Tell tale stream isn't always the best indicator (they get clogged up). Run some heavy monofilament up the opening to try and clear. Weed eater line is good.
Check to see if the motor is operating above proper temps (130-140F or so on the top of the head). If it's too hot to touch, it's too hot. Running on muffs doesn't help much for testing as the hose pressure does some of the work of the pump -- but should cool the motor if there are no blockages. Idea of gashes in the copper tube is kind of curious, so might be misunderstanding. Grommet can be a problem for reconnecting.
If it's a salt water motor or a river runner, you may need to do some more flushing to clear it.
3000gtman
Let me clear it up. The copper pick up tube isn't chewed. The plastic tube part on the water pump is chewed some. I installed the new grommet but maybe I did it wrong? And I've removed my tale tell and flushed the hole. Good stream no blockage. Fresh water ran.
oldboat1
On top of it, sounds like. Think I would check it's temp to be sure (old touch test works pretty well.)
3000gtman
After I installed the water pump it ran great. Cool to the touch and good stream until I tried today. Like I said I thought I got the copper Tube in all the way. I'll test it in the morning but I'm certain I got it all the way in now and not sitting on top then I'll do the touchy test
3000gtman
Ok tested again no water at all. Removed tell tale fitting at the head. Still no water. Removed lower unit again and openEd up the water pump. Found my lower oring that goes between impeller and wear plate in pieces. Cleaned everything and installed it with no o ring this time since my old water pump didn't have a oring in that position either. Fired her up still no water...I put some water in the tell tale hole and tried again...now I have a weak stream..for about 3mins running. Engine temp at top of head 115. But note that when I first changed the water pump she shot out of the tell tale great! Any ideas? Impeller key is still there. The shaft is hard to turn by hand but can be done. Impeller looks ok I mean it's a brand new kit.
3000gtman
Aftermarket kit. I pulled it apart and found that grease was blocking the impeller water exit. Cleaned it all off and she ran great. 3hrs or so on the lake today no major problems just tuning issues :)
