water pump help
joe johnson
i need to buy a new water pump and my original one had a steel pin for the impeller now im seeing their is a wedge lock pin and a half moon one my question is does it matter what one i get and im also wondering if one is better than the other
steelespike
Would help if you give us the year and hp.
Look up a pump for your motor it should be correct.If yours is a pin drive the impeller you select for your motor should be correct.
