water pump couter rotation question
tlrche
I have a 350 chevy converted to mairine application with a heat exchanger. My question is do they made a marine 350 water pump counter rotational?
Bt Doctur
Re: water pump couter rotation question
Most are bi-directional ,what are you trying to accomplish?
King P.V.
Most, but not all, serpentine belt engines run the water pump (circulating) backwards from a "normal" belt arangment. But there are a couple of different serpentine belt set-ups to check... The pump will also be e.z.ily visually confirmed as being different..
