midsized johnson
Thread starter- Joined
- Jul 28, 2005
- 155
I have an '86 70 hp Johnson with a pre-79 lower unit. I put in a water pump kit for an 86 Johnson but used a pre-79 impellor. The only difference I can see in the kits is that the upper "cup" where the impellor sits is one piece on the newer model wheras the older model is a split ring, 2 piece cup. The newer impellor has a sort of swedge key to hold it in place as opposed to the old style key. Anyway, after installing the kit and reinstalling the lower unit, my thermostat doesn't seem to be working in that water comes out of the exhaust ports like niagra almost immediately after startup. Prior to the job, water only flowed out of the ports after a few minutes at idle and, of course, when I was running under load. While I appear to have sufficient water flow, my concern is that something isn't right, causing the power head to heat up too quickly, causing the thermostat to open immediately afer startup. The power head is heating up, as it is hot to the touch after a couple minutes (or less) of idling. I replaced the thermostat with a new one, and it does the same thing. All of this makes me wonder if water flow is a problem. Conversely, I have a ton of water flow as evidenced by the water flowing out of the exhaust ports.
