water proof i/o engine cover
foilled
best way to make or buy a and completely water seal an I/O engine hatch and even the gas tank cover to. its a 87 larson delta 250 sport cruiser
wahlejim
Master Chief Petty Officer
OK, curiosity is getting the best of me. Why do you need a waterproof hatch?
wahlejim
You are most likely going to have to fabricate something based on the dimensions you have to work with. Build it out of exterior grade plywood, glass it over, gelcoat it, install.
With all of the makes and models of boats out there, I would be surprised if you found something that fit perfectly. If you build it yourself properly, you can make it the way you want it and it would last the life of the boat.
One thing to consider while doing this is water drainage. Make sure the water that is on the deck has a way to drain off the deck or into the bilge and get pumped out.
Ayuh,..... My motor boxes don't leak,.....
What do you have for a motor cover now,..??
foilled
some homemade wood made of 2 piece previous owner made. middle connections of two pieces just leaves water all over engine and edges fill up and overflow to
Redrig
I recently built mine out of exterior ply , sealed with the old timers formula I found in this forum .
Sealed it well , I will dig up some pics
hogbare35
I had a problem like this on an old Wellcraft i had. Water would drip in on motor where the cover fit to the inner transom. I cut a piece of 4" PVC cut in half length wise , bolted it to the inner transom to make sort of gutter to run the water off the engine. .Worked pretty good. Just a thought.
John
to have a water-tight seal is to have powered hatches with either pneumatic seals, or compressive seals and a knife-edge
to have a weather-tight seal is to have a coaming with a cutter, and a return edge on the hatch that drops into the gutter
I would correctly build the hatch to drain into the coaming gutter
