water problem
kanthon9
i have a 1984 force 85 hp motor. i have no water flow. i took the water pump out and it looks good. need help
88BLiner
Re: water problem
Check waterflow tubes for blockedge!
mauiboy
Re: water problem
Is the motor getting hot. You said that you have checked the impeller, Mine looked in great shape to but I found out that it was spun the the inside would spin but the rubber would not after I replaced it with a new one it pumped good
