I just installed a water pressure gauge on my 2002 Mercury 150 Saltwater motor. When running at about 4500-5000 RPM, the pressure is reading around 10 PSI. I'm not sure what the pressure gauge should read. I installed the gauge because of the low tell tale stream at start up and idle. The tell tale flows fine at higher RPMs. So, does anyone know what the water pressure should be on this motor? Also, if anyone knows what RPMs the motor should be at idle that would also be helpful to me.
Thanks for any help yall can give me.
