water pressure guage
rrossi
I have a 1978 140 merc straight 6 i need to know how and wear to install a water pressure guage
Chris1956
Re: temprature sender
A temp gauge is useless on that motor. It will run dead cold most of the time and then overheat, if something is wrong with the impeller/waterpump.
I recommend a water pressure gauge. It will have a few PSI at idle and more at cruise. Monitor the gauge for changes.
RadarRick
Re: water pressure guage
Hey Chris
The man is asking about water pressure gauge - asking for ideas on installing.
Chris1956
Sorry early morning or senior moment....
If the motor has a threaded pipe plug in the cylinder head water jacket, that is the place. If not, remove the black plastic elbow that goes to the telltale and install a brass tee into the threaded port. Now install the hose barb to the gauge on one side of the tee and the telltale elbow on the other side.
donaldboyer
Hi, I am looking at installing a Water Pressure gauge on my 1988, 3 cyl, 2 stroke, 90hp Merc.
Am I correct in thinking that I can cut the hose that runs from the engine to the tell tale, install a tee, fit each end of the cut hose on two legs of the tee, and run a hose to the gauge from the remaining leg?
I would assume it doesn't matter where the hose to the gauge reads the pressure as it would be constant all through the system??
Also, do I need a Merc gauge or would a generic suffice? What pressure range should the gauge cover??
Thanks in advance!
Donald.
electricjohn
I installed a small gauge in the head up by #1 where the brass plug is (was). Think the thread is 1/8-27 NPT. 7-9 psi @ idle, 14 psi at WOT.
Chris1956
Donald it is better to install a brass tee in the cylinder head water jacket, as I described. You will get a more accurate (higher) reading. Now since these motors have so little water pressure, I think accuracy is important.
donaldboyer
OK, I'll attach a tee at the head.
What psi range am I looking at for this engine?
