mark_hannah2002
Thread starter- Joined
- Sep 6, 2003
- 7
40HP Johnson Model RDSL-25D Sn# 2362579<br /><br />I was replacing the Impeller on my water pump, and noticed some odd things.<br /><br />#1 There is two outlets on the top of the water pump housing, but only one had a rubber grommet. The one without a rubber grommet has no hole going into the water pump.<br /><br />#2 I have two tubes coming form the upper unit, one goes to the water pick up on the bottom of the prop and the other goes to the water pump grommet.<br /><br />Is it possible that the water pump housing was replaced with the wrong one or did they manufacture this housing universaly, and no tube goes into this closed off hole.
