Water on plugs
Reming870
I started having problems this season starting the engine. Went through everything and noticed water on the plugs and plug threads.
I pressure tested the cooling circuit (antifreeze) and all is OK.
Can condensation cause this much of a problem or is it possible both risers or exhaust manifolds are bad?
5.7 L / 2009 / MPI / Alpha One Gen II
achris
More fish than mountain goat
Re: Water on plugs
I would not expect a 2009 to have manifold problems, especially since they are 'dry-joint'. I would also not expect condensation to be that much a problem. Have you put a scan tool on the computer and read the codes?
Chris.......
Reming870
Re: Water on plugs
Is the water on the exterior or interior of the plugs?
Water was present at both.
Exterior and threads were wet, Soaked.
Interior also wet, not soaked, but damp.
Exterior manifold and riser are wet from condensation.
Reming870
Re: Water on plugs
Chris.......
I have not checked the codes recently, but a couple months ago when she wouldn't fire at all there were no codes.
Reming870
Re: Water on plugs
Please also note that when and if she finally fires it is rough initially and smoothes out quickly. White smoke (water vapor?) heavy on the start-up then clears quickly. Boat is on a trailer. I am assuming the rough start are the misfired cylinders?? Problem will not occur unless the engine has not been started for a couple weeks.
I did have an overheat issue this year when the sea water pump impeller (motor mounted) failed. Overheat was not severe as I shut down the motor right away on alarm.
New fuel filters, water separator from last time this happened (late-August).
Reming870
Re: Water on plugs
Bump...
Any other ideas as to why there would be a lot of moisture on the plugs?
SangerDX
Re: Water on plugs
Now that sounds like water has leaked into the cylinder(s). Runs rough because of the high compression since water is taking up space in the cylinder, smokes as the water is burnt out. Have you done a compression test? I would think that either a head gasket or intake is leaking water.
Fun Times
Re: Water on plugs
Also with water connected to the stern drive, pull the spark plugs out and crank the engine over while looking for water to spray out of the cylinders.
CharlieB
Re: Water on plugs
What was the cause of your 'little' overheat? How did you determine that and what have you done to repair it?
Even a 'little' overheat can be enough to blow a head gasket and/or warp a cyl head. A cyl leak down test is in order to determine if there is a problem witih the head or gasket allowing water to enter any cyls.
Sorry.
alldodge
Re: Water on plugs
Whats the possability that the dry joint risers developed a crack during the over heat?
Reming870
Re: Water on plugs
I did a pressure test and all was fine.
The overheat was from a failed impeller in the sea water pump.
The problem is on both sides.
How do I test the risers?
achris
Re: Water on plugs
I guess anything's possible...
Usually 'testing' elbows is done visually. I usually pull them off, flip 'em on their heads and start hitting the top of the exhaust passage with a decent screwdriver. If I punch through, it needed replacing. Also do a good visual on the gasket surfaces, and the inside of the elbow, looking for water tracks... If an elbow if faulty, it's usually pretty easy to see.
Chris.........
