Water muffs
valvebounce
I have a 1999 25hp 2 stroke long shaft Johnson,I need a set of water muffs.Would a single water feed set be ok?
Some have twin feeds from the connector.
Sea Rider
Will need to have a good water pressure on hose and pray that water will not be forced side of muffs due to u poor U shape bar not pressing ear tight againts lower water intake..
Happy Boating
kmarine
on some drive where the muffs don't fit well I use duct tape to make sure they do not slip off. it helps if everything is dry first.
valvebounce
Thanks gentlemen,the type I intend to get are advertised as 10hp to 40hp,Evinrude and Johnson suitable.
