Water level too low to get boat off lift - ideas to help?
Texasmark
Re: Water level too low to get boat off lift - ideas to help?
Don't remember where I got them but I have plastic strips on my trailer that screw into the tops of the bunks...made for the purpose. Years ago Dilly made a tilt trailer where the main part of the frame pivoted at the root of the tongue allowing the boat to slip into shallow water.
With that thought in mind, if you had something like plastic strips and could operate the front and rear of your lift independently, it might work. Retrieval of the boat may require something like a winch mounted on the dock whereby you could winch the boat back on similar to winching a boat onto trailer bunks.
On dredging, if allowed be careful. I saw a tragic accident (for lack of a better word) whereby a guy built his bulkhead and covered boat dock with lift and then, due to low water, dredged out the center. Result was that the bottom of the support poles moved into the deeper water in the center, the whole shebang became unstable and fell over.
Funny, the other day were were out and noticed a lot of new covered docks, most with lifting devices. Most appeared to be professionally constructed and were first class. However, not one had any cross bracing. I found that odd, especially when you consider that something like a Ski-Nautique or similar somewhat heavy boat was suspended under the canopy.
Mark
bruceb58
I am assuming he has a floating lift so the problems with support are not an issue.
Bubbasboat
A photo of your situation, a general location, what type and size boat you got, etc., would be helpful. Can you extend your dock and move lift further out, are you in a generally shallow lake? How much more water do you need to easily float the boat of the hoist, 1", 12" or ? More info please!:D
Anyone have this problem when water level is down. I have a lift that is for shallow water but with it lowered to the bottom of lake bed, I have a difficult time getting the boat off the vinyl-coated bunks that my fiberglass boat rests on. Last year I sunk the base of the lift into the ground, which helped, but I am looking for an easier solution? I am wondering if anyone has any ideas for changing the vinyl material that coats the rails the boat rests on, or if there is something I can put on the vinyl that would reduce friction, maybe paraffin wax or something of the like?
Any ideas greatly appreciated. Boat going in soon....
Chris
crabby captain john
With all the refs on a lake ~ I thought it was to get away from the cold so many from WI are moving south. Maybe it is to get away from the liberals..
bonz_d
Thr west coast drought is all part of the liberal global warming therory and the east coast polar vortec
Bubbasboat
Forum Rules
Moderators will edit or delete any posts in violation of the following, and may warn, issue infractions, suspend or permanently ban any member for serious or repeated violations.
1. This is a family site. The use of foul or insulting language or the posting of any material not judged suitable by the Moderator Team is forbidden. Disagreements on any topic must be conducted in a polite manner using courteous language.
2. Political, religious or socially controversial topics are not allowed.
3. Do not post copyrighted material or request that anyone else violate copyright law.
4. Attacks (bashing) on any person, organization, company or other entity will not be permitted. Reporting experiences with any vendor, website or organization must be limited to facts. Unqualified attacks will be considered bashing.
Chief9
How far does your boat sit above the crossmember? Can you pull your bunks apart so the boat sits lower??
Clothman
Thanks for the help. Iv optimized this already and have it sitting less than an inch above cross braces. Not sure what else I can do.
Mi duckdown
clothman. have you given any PICS of your situation. cantilever hoist, Shorestation, sling,What? Maybe I missed the Pics
jbdenver
You may try to move the bunks on the lift out. This will make the pads hit the boat higher up on the V and allow the boat to sit lower. Be careful doing this, if you move them too far out then your hull may get into the steel below. I work for a Hydrohoist shop, so if you post a picture I may be able to help you out more.
the OP is already less than an inch above the crossmember on the cradle. dont thing moving the bunks outward will do much.
Clothman, any chance of moving the lift deeper? if not, time for a rain dance.
