water leek merccruiser 3.7
scat
1st time on here. I have a 1989 3.7/lx 170 hp closed cooling system. Boat has been sitting for 4 years , when I fill the tank on top of the ex/manifold the water drains out through the water intake hose to the out drive. None going into the motor and not dripping into the boat but I just replaced the gimbal and have the out drive off and it leeks out my 3/4" intake hose. I took the tank off and the gasket looks rough but I thought I would see water sitting at the top of the manifold but I don't ? So I am thinking it is mixing together somewhere down lower. This has a log tank on it can that leek fresh and raw water together ? or is there something else I should check ?
Thanks :confused:
Don S
Re: water leek merccruiser 3.7
Pressure test the heat exchanger. You will probably find your problem.
guyaverage
Hopefully there is one and some hack didnt convert this to an open cooling system.
Ayuh,... Welcome Aboard,...
Sounds like yer either Missing some pieces, or the exchanger is full of holes, where there shouldn't be...
Got a picture,..??
