Re: Water Leaking
If the motor is a salt water motor, the salt has probly ate a hole through the cover, as I don't belive there is supose to be a hole there. I think it is the popit valve cover. If gas was left in the motor for extended time the carb might need to be cleaned or rebuilt and the water pump impeller might need replaced if not done in the last 3 years.
Oldman570
