I have a 2001 mercruiser 4.3 serial number is unknown due to engine being changed and the number that is stamped on the flame arrestor cover is faded out to where it cannot be read. The serial number for the outdrive is OL783082. The transom serial number is OL886317. I keep having water drip through the shift cable onto the valve cover. I have tried everything I can think of to try and stop the leak. I have pulled the outdrive and replaced the large oring, the water jacket oring and the 3 orings on the U joint shaft. I have replaced the upper shift shaft bushings and seals where the upper shift shaft goes through the bell housing. I have used quicksilver for all the replacement parts except for the shift cable. The shift cable is Sierra. The shift cable was replaced about a year ago with a new bellow. I cannot seem to find anything wrong inside of the bell housing. I also cannot find anything anything lodged or broken in the exhaust tube or bellow area. I do not know if I were to change all of the bellows if that would help. I have noticed some cracking on the inside of the u joint bellow so it will probably be time to change then soon. When I do replace the bellows I will be using OE bellows from mercruiser. Is it possible there could be a crack in the bell housing causing water to get into the area where the shift cable is in the bell housing.
Any ideas or suggestion on why I am still having water come through the shift cable or where the water can be coming from? Any way I can figure out what the serial number of the engine is supposed to be based to the serial number of the outdrive?
