Water leak in Volvo SX Lower unit
scb1712
Hi All,
I just did a pressure test on the intake section of my 1999 Volvo SX-M stern drive. I am getting water coming out of two small holes on both sides of the drive up near where it attaches to the upper unit (see photo). I'm pretty sure i shouldn't be getting water coming out here and that this represents a leak somewhere in the drive. However, before pulling the lower unit off, i thought i better check here first. Anyone have any ideas??
scb1712
Re: Water leak in Volvo SX Lower unit
Well - i think i might have found the problem in case anyone else runs into this. The seal on the inlet tube into the lower unit was shot. Someone had tried a band-aid fix by wrapping it in electrical tape:facepalm:.
If i'm replacing the lower seal on the pick-up tube, does it make sense to also replace the upper seal? I can't seem to get the tube out even though i think its just a pressure fit.
DrNo08
Im confused. I thought those two holes on each side are where the outdrive "pees". Are you sure water isn't supposed to come from those 4 holes when idling on the muffs or in the water?
0352Marine
I have water coming from my 4 holes and I have no cooling problems. I pretty sure water is supposed to come out of those holes
Don S
They are drain holes so those pockets in the castings drain. When running on muffs the exhaust pushes the water out...
scb1712
Good to know - so if i see water coming out of them when running on muffs i won't worry. Is there any concern about those holes sucking air when up on plane? Either way - the lower water tube seal was shot.
Don S
No.
