While rewiring my 20hp merc, I accidently broke off the corner of the plate covering the left side (from behind) of the motor. The break occured near the top lefy bolt that attaches the cover to the block. When I started the motor, water leaked from the crack so I got another cover from a spare motor, gaskets and put it all together. Then it leaked water from the top left bolt so I cocered it with marine tech and let it dry. OK now it doesn't leak but the engine ran really rough for about an hour then settled down and ran fine. It was pumping water OK too.<br /><br />Is it possible that I got water into the cylinders on the other side of the water jacket? I also put new gaskets in the carb so its possible, I guess, that I got a small piece of trash in the jets while I had it apart. I'm not one to mess with the engine while its running fine but I can't figure out why water would leak out of a perfectly good bolt. Any ideas?<br /><br />Thanks.
