water leak from freezing
sjs0246
This is a '97 60hp Mercury on a 15 ft Whaler. SOMEONE did not do their winter maint and now with a hose on the water intakes there is a spray of water from in front of the lower unit. Inspection shows a small crack. Can this be filled with JBWeld or something similar to stop up the crack or am I looking at something major?
Re: water leak from freezing
You might post a picture. Normally outboard are self draining. The only normal danger is for water that got into the gearcase oil to freeze. Water external to the gearcase is not usually an issue
sjs0246
Have to wait until after the weekend. Thanks
