water jacket gasket removal on a 402 (40hp)
kenters
whats the trick?
i can get at all the bolts but the bottom one doesn't have a captured nut on the opposite side, so it just spins, and cant fit a wrench or nothing in that tight space.
so i started to try to take the bottom of the hood/cover (?) off to get at the nut from the bottom, but that looks like i have to disassemble most of the upper half to get it off.
there has to be an easier way.
Any suggestions?
Phil303
Re: water jacket gasket removal on a 402 (40hp)
i have the same issue now with my merc 800, i can't get to the bottom nut without removing the lower cowl, which looks like i have to dismantle most of the engine to get too!
kenters
no easy way, in fact wasted time avoiding doing it the right way. which ended up being the easy way in the end.
