SavinRaven
- Sep 16, 2021
- 228
Be careful. Volvo used 2 routing setups for this flush port.Can I run my engine without muffs, if it has this?
This is my first time getting the boat ready in the spring and I was inspecting the engine last night and noticed a blue cap with a water tap on it. It looks like a garden hose will hook up to it and from searching the net it looks like it's a freshwater flush hookup. So does that mean I can...forums.iboats.com
Disregard found this article regarding this topic.
Mines a 2004 as well. I ran it the other day on it no issues here.Be careful. Volvo used 2 routing setups for this flush port.
On earlier engines, that port was used to flush the engine with the engine stopped since the port was after the impeller.
On later engines, this port is before the impeller, so, it is possible to run the engine with water on that fitting. I think the switch over was in the early 2000. Mine is a 2004 and it is the later setup.
