Water in two cylinders
vaboatdoc
Working on a late 80's model johnson 60hp 3cyl. It had been overheated badly and before it had been repaired it sat for a little while. Now that the waterpump has been repaired and operating good there is water entering into the bottom two cylinders while running. Already pulled head and checked head gasket and showed no signs of water passing anywhere and replaced head gasket. Checked head and cylinder walls for cracks none present. Pulled exhaust cover and checked for cracks or anything out of the ordinary and replaced gasket. Also ran motor on clean test tank. What would be the next posibility for water intrusion into the lower two cylinders. Any assistance or input would be greatly appreciated!
