FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Well, not knowing what you are working on. It could be prop shaft seals, drive shaft seals, seals on drain/vent screws, shift rod seal, solenoid cover gasket.
The most common cause of water intrusion is failure to use new gaskets under drain/fill and vent plugs. It is so simple to eliminate that before tearing that sweet little Johnny apart.
