Water in oil *Update*
f_inscreenname
Hi;
Total f_in dumb *** here.
Sometimes I wounder how I don't end up killing myself with my stupidity.
All that work down the tubes and all for what would have taken 15 seconds to do.
Next time I'll make sure I install and tighten all the head bolts down.​
ziggy
Re: Water in oil *Update*
ah, don't feel bad f. had me a boss once. told me. if ya ain't making mistakes. ya ain't doing nothing....i always liked that idea.......good job on the find.......
Gary H NC
See...should have bought a Bilgeliner...NOT!:D :D
That was a retarded thread! They ask your opinion then bash you for it..
Glad you found the problem before engine go boom!
Don S
Keep doing things like that, and you will make one h__l of a professional Marine Tech some day. Cause you will know all the mistakes that can be made. I've made worse mistakes than that................
Ayuh,............
Been there,..... Ain't Done Exactly That,...... Probably Dumber though.......
Btw,...........
Gary has been reading that 2, 1/2 Year Old Bilgeliner Thread,......
Just so you'll understand What he's talking about............:D
Gary H NC
Thanks for explaining that.....long day of driving will do that...duh!!
Limited-Time
No sheet f'n, I won't admit some of the dumb azz sheet I've done, but you're still in the "brain surgeon" category compared to me.;):)
Reel Poor
Glad ya found your problem. I'm not going to tell on myself either. But I bet you don't ever do THAT again. ;)
f_inscreenname
Ooooooohhhhhhh Noooooooooo!
Not the Bayliner thread!
I must admit it was not my brightest moment but its a whole lot better then buying parts like a block.:eek: This time the heads will go on before it goes in the boat. Maybe I just need to see it better.
f_inscreenname
I forgot to add, The motor is out and torn down to the block. 90% of it is cleaned up and I am starting to put it back together. :)
