justright1998
Thread starter- Joined
- May 15, 2011
- 23
I just recently had my twin 7.4,s rebuilt from the heads up. Had the heads machined........new manifoldss ....risers ..new gaskets etc. I then put about 50 miles on them.no problems whatsoever. I checked the oil after each run ..gauges all stayes where they should be untill my last trip out> As we were about three milkles from my hhome doock, my wife (nervous nelly) said what was that? I didn't notice anything untill I glanced at my synchronizer and just as I did, my starboard side was just coming back up to "par". It couldn't have been for more than two seconds by the time she noticed something wasn't "right" untill it they "evened out". We continued to our destination (about another two miles) without a problem. On the way home after running about another four miles with no problems.....The starboard engine bogged down. I opened the engine compartment and noticed a "clacking" noise" (sounds like a rocker) toward the front of the engine. They are V drives so it would appear to be the back. I turned off the engine and we returned on the other. My first thought was that maybe I had some sluge residue drawn up into one of the valves etc and it was keeping the oil from reaching that particular area. I decided to empty the oil and any additional sludge i could get to and replace it with a light weight oil and new filter to start from scratch and empty once again.. I ran the engine for approximately 30 minutes at my dock to circulate the new oil through the entire engine . The oil pressure was good , temp etc the Manifolds and risers didn't get hot.
The block is fresh water cooled, The manifolds and risers are saltwater cooled. When I emptied the oil......You guessed it....It looked like a vanilla shake. Before I go on the normal assumption of a blown head gasket and start ripping this engine completely apart,, I just was wonering if anyone would know if there was any other way I could have drawn in the water. New manifold or riser gaskets didn't seat well, Oil cooler etc? Antifreeze level seems OK so I am going on the assumption that it is saltwater in the oil. TNX in advance. sorry for any typos.......I left my glasses at the marina ;(
