Re: Water in merc lower unit gear oil?
If you had a lot of water in it, it will come out first when you pop the bottom drain---you would know it. If it is just a little dab in there, you may have to drain a bit more to see it. It won't foam, but it will chang the color to a murky looking stuff.
